CAI decision ?
Old Jul 28, 2009 | 09:32 PM
chambers's Avatar
chambers
Should fit the airbox just fine like ramhunter1 said. You may need another coupler to get a good fit on the other end at the TB, and the hole for the IAT sensor might be on the wrong side so you would have extend the wire or plug the hole and drill another.
Old Jul 28, 2009 | 09:53 PM
Red Ram 07's Avatar
Red Ram 07
what about the short ram intakes on ebay? do they just pull in hot air ?
Old Jul 28, 2009 | 10:08 PM
chambers's Avatar
chambers
When your sitting still they will, but once you get moving it won't matter.
Old Jul 28, 2009 | 10:17 PM
BadHab1t's Avatar
BadHab1t
short rams suck had one on my 99 and and it was minimal at best the only reason i used it was i had a fastman tb and helped it breath...heres the one i just put on its priced right and performs as good as the rest.....http://cpwstore.carpartswholesale.co...S-V218205.html.
Old Jul 28, 2009 | 11:17 PM
davb673's Avatar
davb673
I had a 4" PVC pipe intake, but dumped it in favor of a 3.5" mandrel bent exhaust pipe. I even reused the hemi hat rubber doughnut to mount to the throttle body. Pics are in my gallery... https://dodgeforum.com/forum/members...ntake-mod.html
Old Jul 29, 2009 | 10:00 AM
Red Ram 07's Avatar
Red Ram 07
what is the difference between the intake setup on the 04 and an 07 ?
what modification would need to be done to make it work?
Old Jul 29, 2009 | 11:41 AM
chambers's Avatar
chambers
I don't think there is much of a difference if any. Everything should mount up fine, but keep in mind that the mounting bracket on the filter end of those intakes tends to break so you may have to fab up a new bracket.
Old Jul 29, 2009 | 04:25 PM
froto'sride's Avatar
froto'sride
I have one of these $30 cai and have had no problems with it. I kept the original filter for a while but eventually went to auto zone or o'reilly and bought an better one. I am going to build me a box to help isolate the filter from the rest of the engine and while i'm at it I'm going to make a jetstream scoop.
