HID Question....yet again
Old Aug 1, 2009 | 05:26 PM
MeTaL's Avatar
MeTaL
Default HID Question....yet again
Ok, so I bought the kit from the vendor off here for my '03 Ram. I get the kit all installed and low and behold....flickering, so I contact the seller and we figure out that my kit was missing the capacitor wire. Today I get around to finally attempting to reinstall the kit with the capacitor wire, get 'er all in and bam...still flickers. I'm not sure if I'm overlooking something or what, but I'm gettin agitated with having to rip the entire kit out and reinstall it. Anybody else have a problem after installing the bypass wire or what?
Old Aug 1, 2009 | 05:30 PM
SilverBullet08's Avatar
SilverBullet08
dude in the same boat as you. i tried wiring with the relay today and i got flickering... so i went with the old way i had it wired. which was ballast, capacitor, and factory harness. no flicker there just when is start my truck i get lamp out. but when i turn the lights on it goes away. the lights work fine just annoying seeing the lamp out on the dash. and i agree taken these headlights out is getting old...
Old Aug 1, 2009 | 05:34 PM
MeTaL's Avatar
MeTaL
hell if my lights worked, I could deal with the lamp out light until a solution was figured out. My lights flicker no matter what I do it seems...not sure what else to try
Old Aug 1, 2009 | 05:37 PM
SilverBullet08
did you try how i wired it? i still want the lamp out off my dash though
Old Aug 1, 2009 | 05:39 PM
MeTaL's Avatar
MeTaL
what'd you do, just not hook the relay to the battery?
Old Aug 1, 2009 | 05:41 PM
SilverBullet08
yea no relay at all. thats what caused flickering for me. it goes ballast then capacitor wire and then the wire that goes into the factory harness. then just attach the bulb. mines works fine just get the lamp out as i already said
Old Aug 1, 2009 | 05:50 PM
MeTaL's Avatar
MeTaL
just tried it without the relay and the lights don't come on at all...all that happens is the ballast is clicking on and off and the lamp out light on dash
Old Aug 1, 2009 | 05:52 PM
SilverBullet08
weird works for me... i want to get this figured out though
Old Aug 1, 2009 | 07:07 PM
MeTaL's Avatar
MeTaL
I went and messed with them again...tried a different ground for each bulb and what not. Turned them on and they still flickered, but when i turned them off and the truck off they were still on and flickering....I'm totally stumped
Old Aug 1, 2009 | 07:19 PM
SilverBullet08
me too man...
