my trailer wiring is messed up, anyone help?
Old Jun 9, 2010 | 11:03 PM
jtmiller68's Avatar
jtmiller68
I am having the same problem. Did you ever get an answer to this problem?
Old Jun 10, 2010 | 01:05 AM
Marx's Avatar
Marx
all you do is turn the *** on the top of the fuse box and the lid comes off easily
Old Nov 21, 2010 | 07:33 PM
fredsr55's Avatar
fredsr55
Sorry you all I had same problem. It is in the PCM.
Old Nov 21, 2010 | 10:11 PM
Lecrict's Avatar
Lecrict
you need to read MDinger's post again. He's got the right T-shooting. If the truck works fine without the trailer hooked up, then the prob is in the TRAILER. Chec k the resistance, not the Voltage on the trailer. Check the wires on the trailer, like ya did with the truck
Old Mar 29, 2011 | 11:52 AM
maintwarrior's Avatar
maintwarrior
Default 2006 Ram 2500 trailer lights
My 2006 Ram 2500 also is experiencing problems with the trailer lights. The lights work fine on the truck and when I hook up a trailer the running lights and license plate illumination on the trailer work but the turn signals, stop light and hazards do not, however, the lights continue to work as they should on the truck. I looked for a short in the harness or a short to ground with no luck. I have identified this fault with three different trailers.
Old Mar 29, 2011 | 03:46 PM
Geezir's Avatar
Geezir
If the problem was on the trailer then the truck side of the trailer wire harness would have voltage for both the right and left side signals. The fact that he doesn't means the problem is truck side and NOT trailer side.
I'm also having the same problem but I think mine is a loose connection right at the bumper because I had no power but when I reach behind and move the harness around I can get everything but the left side.
fredsr55, out of curiosity for a worst case scenario how much did it cost you to replace your PCM?
Old Mar 29, 2011 | 03:55 PM
herring_jerritt's Avatar
herring_jerritt
i work at a trailer place in texas. if you take it to any major trailer repair place the will have testers that they can hook up to the truck and the trailer which will tell you if the problem is in the truck or in the trailer, if they are like us they will do this for free. Second, the truck lights and your 4-way/7-way plug on your truck are on 2 diff systems, so your truck lights are still going to work even if your trailer light wiring on your truck has a short. Hope this helped.
Old Mar 29, 2011 | 07:10 PM
marky0304's Avatar
marky0304
From my experience and VERY similar sounding problem, Marx is 100% correct! There is a printed flex circuit thing under the relays/fuses that will get corroded. I tapped into my truck wiring with an in-line 20 amp fuse for the particular trailer lights. Haven't has 1 problem in over 2 years.
Old Mar 30, 2011 | 01:27 PM
Geezir's Avatar
Geezir
That's my plan if I can't get my harness to work.
