BIG problems!!
Old Aug 6, 2009 | 09:02 PM
mmachac's Avatar
mmachac
Default BIG problems!!
ok i just installed pacesetter LT headers and y-pipe with a aero turbine muffler and no cats. it ran fine all day until that night i lost control of the throttle and the check engine light came on also the red lightening bolt that flashes. i pulled the codes with the SC programmer and these are the codes. p0016( crankshaft/camshaft timing misalignment-bank1 sensor 1) p0405(egr position sensor circuit low) p0344(camshaft position sensor intermittent- bank 1 sensor 1) can someone please help me??????
Old Aug 6, 2009 | 09:57 PM
reefguy89's Avatar
reefguy89
did it like rev up and down like it was redlineing. My did that when my camshaft sensor went bad. It happend like 2 years ago i think it was like a 2 or 3 hundred dollar (cant remember exactly) fix at a shop.
Old Aug 6, 2009 | 10:09 PM
lxman1's Avatar
lxman1
Site Moderator
What year and engine. Important info missing.
Old Aug 6, 2009 | 10:29 PM
Bluesmanjesse's Avatar
Bluesmanjesse
I'm guessing there is a wire melted to your headers somewhere,almost the same thing happened to me after putting headers on a 94 chevy I used to have. I had an MSD ignition and MSD wires one of which melted to my headers and my truck started bucking and stuttering then it died, dash lit up like a christmas tree! Replaced the wire and shielded them all from heat really well and I had no more problems.
Old Aug 7, 2009 | 12:04 AM
mmachac's Avatar
mmachac
it a 05 ram daytona 5.7. and when it has the engine codes it idles rough and around 1500 rpm and i dont have any control of the gas pedal. but if i clear the codes it will run fine for about a minute as if there wasnt a problem but the codes pop back up and runs like crap. maybe it could be the headers melted some wires but not sure cus i dont see why it would run perfectly fine all day and all of a sudden get a problem. any other suggestions?
Old Aug 7, 2009 | 12:38 AM
Bluesmanjesse
It only takes a minute or two for headers to get hot enough to melt wires again.
Old Aug 7, 2009 | 01:14 AM
lxman1's Avatar
lxman1
Site Moderator
Yup, sending a signal to ground will drive a PCM crazy!!
Old Aug 7, 2009 | 07:25 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Exh headers run what temps? 1600* +/-? It doesnt take much an anything to melt at those temps.......LOL
Old Aug 7, 2009 | 11:39 AM
mmachac's Avatar
mmachac
problem fixed!!!! the sensor connected to the transmission on the passenger side wires were melted and i replaced them and it runs perfect now. thank!!!
Old Aug 7, 2009 | 12:55 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Good call Bluesmanjesse.........good call.
