Grinding noise after breaking
Old Aug 7, 2009 | 10:53 AM
espinosafell's Avatar
espinosafell
Default Grinding noise after breaking
I get this grinding noise when I make a full stop and try to go, I get this grinding noise that is coming from the brakes. I changed the front rotors and Brakes yesterday... I did not touch the rear, someone told me it may be the E Brakes...
Old Aug 7, 2009 | 12:44 PM
MontanaRAM's Avatar
MontanaRAM
bad pads in the back.
Old Aug 7, 2009 | 12:45 PM
espinosafell
So it might be the pads in the rear... So just change those...
Old Aug 7, 2009 | 02:32 PM
abarmby's Avatar
abarmby
Try and isolate the noise by having a friend listen at the side of your truck as you pull up.
Have him rolling with you side by side is best as your duplicating a realistic road speed.
When you have isolated if the noise is coming from the front/rear, tear into the wheels tyres and brakes etc.
Are your rear rotors scored/worn?
Hope this elps?
AL.
Old Aug 7, 2009 | 02:35 PM
espinosafell
Im going to check my rotors and brakes once I get out of work... If things look wierd or bad Ill try to take picutres & post him here... And they shouldnt be coming from the front since I just changed the front rotors and brakes yesterday...
