2003 Ram, need engine block heater
Old Aug 9, 2009 | 05:58 PM
af92t1's Avatar
af92t1
Default 2003 Ram, need engine block heater
I just moved to North Dakota from the south and it has been suggested that I get a block heater for my Dodge Truck. The dealer wants $150+, but I know I can get one cheaper and do it myself. However, I am not too sure what type of block heater the Hemi requires. Any info on this from anyone? Places to buy; advice on installation? Btw, the truck is a '03 1500, 5.7L Hemi, 4x2. Thanks.
Old Aug 9, 2009 | 07:14 PM
AF_HEMI's Avatar
AF_HEMI
where in ND are you?? dont tell me you just moved to minot. I just got here friday
Old Aug 10, 2009 | 07:01 PM
af92t1's Avatar
af92t1
Yeah...Minot. I got up here about 2 1/2 weeks ago. I have lived in the south for pretty much my entire life, so the cold weather is something I will have to get used to. I am assuming the block heater for the Hemi goes right behind the starter. Do you know of any other type of block heater that will fit?
Old Aug 10, 2009 | 10:42 PM
AF_HEMI's Avatar
AF_HEMI
nope theres only one kind that will fit. im gettin mine from here
https://www.dodgeparts.com/product_i...oducts_id/1900 cheapest i've found.
what do you do?
Old Aug 10, 2009 | 11:30 PM
cheapbeater's Avatar
cheapbeater
i could use one of these too... where does it mount to the motor?
Old Aug 10, 2009 | 11:50 PM
AF_HEMI's Avatar
AF_HEMI
its near the rear of the block. you unscrew one of the start bolts, loosen the other and let th starter rotate out of the way for easier access. theres a port there you put the heater into. supposedly the hardest part is running the wire to the front of the engine.... total job time maybe 30 minutes
Old Aug 10, 2009 | 11:54 PM
af92t1's Avatar
af92t1
I did some reading up, and it looks like it goes next to/just behind the starter. You have to partially remove the starter, but it seems to be a relatively easy installation.
http://www.supertruckusa.com/Assets/...ion/116785.pdf
Old Aug 11, 2009 | 01:02 AM
Rojhan's Avatar
Rojhan
Minor threadjack:
Huh... After hearing about "Why not Minot" for initial assignment about 25 years ago, somebody that is actually there. "It DOES exist!"
Old Aug 11, 2009 | 01:07 AM
cheapbeater
so is there something in that hole? like a frost plug? or is it just a little pocket the sensor goes in?
Old Aug 11, 2009 | 01:25 AM
crazzywolfie's Avatar
crazzywolfie
i live in canada and all i plug in at night is my trucks battery charger. i find that a good battery goes a long way
