new dodge owner with questions
Old Aug 9, 2009 | 08:07 PM
lslv's Avatar
lslv
Default new dodge owner with questions
hello i have just purchased a 2009 2500 6.7 liter new and have lots of questions. tostart out i would like to know if i can clear 35 12.5 on stock suspension i was told i could but wanted to ask first (i have 17x8 wheels stock. also what intake to add for the most whistle sound, and is exhaust (dpf back) worth it does it add any sound? last is there any advice you guys have for the truck and the diesel would be appreciated. thank you
Old Aug 9, 2009 | 08:22 PM
Pyro's Avatar
Pyro
I Beat Tetris
On a 2500, you could clear 35s, it'll be tight, so you won't have a lot of articulation for offroad, but you'll clear em. The 12.5 wide might be an issue, I'm not 100% on that, but I doubt the stock rims have enough backspacing. Check out the Cummins Diesel section, lot of great info there. And for the most whistle sound, you don't need to change out your intake as much as just remove the silencer ring from the turbocharger.
Old Aug 9, 2009 | 08:24 PM
lslv's Avatar
lslv
thanks for the info
