Fresh air door under dash
Old Aug 15, 2009 | 10:59 PM
ramhead1500's Avatar
ramhead1500
Angry Fresh air door under dash
I need to replace the section that lets fresh air inside of the cab
its under the dash. I have a new one and can't seam to get the old one
out. Can anyone tell me how to replace this? I have the glove box out
and the center piece out also. Any help let me know plz??? Oh, its 2004 model 4.7L
Old Aug 17, 2009 | 04:07 AM
R1mark's Avatar
R1mark
do you have just the door or the whole head piece w/the door in it. if its just the door you can replace it by taking out the blower motor (3 screws) and if you look in there you will see the little motor that moves the door needs to be unplugged and removed, then take out the white plastic insert out. then reassemble. if its the head unit you have to remove the ENTIRE dash which takes about 4.5-6hrs. start to finish .
i've done it 3times on different trucks. it's just like replacing the heater core with the amount of work that needs to be done. it's not hard just alot of screws. and the steering colum needs to get dropped down just 4 bolts. the parts takes about 5min to replace 2clips in back that you cant see.
the dealer sold me the whole housing and everything, he told me that they were having problems with the doors breaking due to the door stop limiter was to far back and causing the doors to break. that was part or the molded housing
hope this helps
Old Aug 17, 2009 | 01:28 PM
ramhead1500
I had to buy the whole piece to. Is there a way that i can just replace the door in there
without taking the whole dash apart. I took the elect switch off the new one but don't know how to get that rod and door out.
Old Aug 18, 2009 | 12:00 PM
ramhead1500
tttttt
Old Aug 18, 2009 | 01:16 PM
R1mark's Avatar
R1mark
to take that rod out you could take a pliers and pull it out i think or take a screw driver and pry it out i cant remember if there were anytabs locking it in there. take the door off the new one so you know how it comes off. since i replaced the whole thing in my truck i have'nt had any problems with the door yet.
Old Aug 18, 2009 | 01:35 PM
Ramdamit98's Avatar
Ramdamit98
Video of an aftermarket replacement.
http://www.heatertreater.net/Dodge%20Ram%20Video.html
