Brake Controler
Old Aug 16, 2009 | 12:49 AM
blackram1500's Avatar
blackram1500
Red face Brake Controler
Bought my Brake controller today and was wondering where is a good place to mount it on the 1500.
Old Aug 16, 2009 | 03:36 AM
AF_HEMI's Avatar
AF_HEMI
you're gonna want it somewhere you can reach while driving. i put mine at the very bottom of the dash panel, all the way to the right side (basically just above the gas pedal). works great there
Old Aug 16, 2009 | 11:25 AM
draco8494's Avatar
draco8494
x2 ^^ mines all the way to the left, but it gets in the way of the obd2 port(i didint install it...)
Old Aug 16, 2009 | 02:58 PM
shadow11's Avatar
shadow11
There is a screw on the bottom right that i use, its right above the gas pedal so that way you don't have to drill into your dash. It holds it in there just fine with only one screw.
Old Aug 16, 2009 | 04:06 PM
cheapbeater's Avatar
cheapbeater
^same here... once in awile i will hit it with my size 14 work boot when i swing over from the gas pedal to the brake pedal
Old Aug 17, 2009 | 11:28 AM
Redsol1's Avatar
Redsol1
I put mine dead center under the steering wheel. It's easy to reach and is out of the way.
La'
Redsol1
Old Aug 17, 2009 | 08:04 PM
blackram1500
Thanks for all your input.....
