Electrical
Old Aug 16, 2009 | 01:12 PM
tankmech's Avatar
tankmech
Question Electrical
On my 07 Ram sometimes when I shutdown and open the door, the radio stays on. Then times I can come out and the radio is on for no reason. Any ideas?
Old Aug 16, 2009 | 09:56 PM
NapaTech99's Avatar
NapaTech99
the ignition power supply is recieving battery plus+ current. check the ignition switch with a sutible test light. On the fuse panel check the radio fuse and see if it has current while the key is off...if so....more then likely the ignition switch or an aftermarket alarm system/remote start.
Old Aug 17, 2009 | 07:46 AM
NapaTech99's Avatar
NapaTech99
are the dome lights on to ?
Old Aug 17, 2009 | 08:06 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Is it a timed feature? Maybe the truck isnt seeing the door open and thus leaving the radio on.
