A little help on towing capacity.
Old Aug 16, 2009 | 04:51 PM
jmzmorr's Avatar
jmzmorr
Default A little help on towing capacity.
Hello all. I am new to this thread and would like some help. I am looking into buying a 2006 1500 slt 4x4 crew cab(hemi). I have a 26' travel trailer i would like to pull. Is this factory towing package going to be ok in 2wd? I want to make sure the sales people aren't blowing smoke into my tailpipe! Thanks in advance.
Old Aug 16, 2009 | 06:16 PM
bulletperformance's Avatar
bulletperformance
if you use the search you will find many threads on this including ones with links to get exact numbers
Old Aug 16, 2009 | 06:23 PM
HammerZ71's Avatar
HammerZ71
What is the weight of the travel trailer? How often and far do you plan on towing it? I'm thinking a 26' model has got to be pretty heavy.
A 2500 would be much better suited to pulling a big trailer and if you could afford it and plan to tow fairly regularly, a diesel would be your best choice by far...
Old Aug 16, 2009 | 07:22 PM
jmzmorr's Avatar
jmzmorr
My trailer in question is around 5000 pounds. The distance for towing will vary and it will be only a couple times per summer that we would be pulling. I want to have the power in a truck for minimal towing use, i don't want overkill for the rest of driving.Thats why i want to stick to a 1500 if it has the ***** to do it. I had 1 dealer tell me i wouldnt even know it was there......
Old Aug 16, 2009 | 09:18 PM
Lifted4x4Astro's Avatar
Lifted4x4Astro
If you have the 3.92 gears you will be fine towing that camper with a WDH. If the truck only has 3.55's, it'll be a dog.
