Changed rear pads... park brake issue
Old Aug 18, 2009 | 05:39 PM
cheapbeater's Avatar
cheapbeater
Unhappy Changed rear pads... park brake issue
Changed my rear brake pads and had my rotors turned. All went well except when I was putting the driver side rotor on... the drum bumped the parking brake pad and it fell off... cheap piece of crap...
well i need my truck and really dont want to mess with that drum setup so i put it back together. i cant hear it rub or anything, but it has me worried anyway. it just barley grabs now and will slowly roll backwards on a hill, moves like theres no brake at all forward.
the other thing i'm worried about is that i pull a boat a lot and i use the parking brake at the landing... so is it hard on the transmission to let PARK do all the work??
anyone ever change these pads? do i have to pull off the hub or something.
thanks
Old Aug 18, 2009 | 08:05 PM
Mega-Hemi's Avatar
Mega-Hemi
I just changed mine about a month ago. Get ready for some fun. I ended up having to pull my axle shafts because the scissor type actuators(what the cable actually hooks to) were both frozen solid. The spring clips I got with the new shoes were junk also, they fell off twice when I was trying to put the rotors back on and adjust the parking brake. They can be put back on without pulling the axles again but it takes a little patience and three hands. All I can say is good luck and if you have any more questions feel free to ask.
Old Aug 18, 2009 | 10:50 PM
cheapbeater
ah shet... im thinking i will just leave them alone for now. they arent hurting anything. maybe i will keep soaking the bolts in PB for the winter and change them in the spring
Old Aug 18, 2009 | 11:02 PM
Wanderer's Avatar
Wanderer
Exclamation
The parking brake pad came off when pulling off the rotor. Spent an over an hour trying to get the new linings on. Then realized the pads I got from autozone had holes that did not match the oem. Had to go to Dodge, $90 vs $40. Ended up just replacing the one wheel.
Caution: Using the transmission to hold the vehicle can only lead to problemws. Allways set the brake prior to putting in park.
Old Aug 18, 2009 | 11:19 PM
cheapbeater
thats what im afraid of... what kind of problems are we talking here??
