3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
Hello everyone,
I am trying to swap out my 07s horn for a different horn but i cant seem to find the horn under the hood. Can anyone tell me where to find it and if you have changed your horn around?
lol i was going to do the same thing and i found that you cant get it out without removing the driver side fender. It is hidden in the middle of the fender. Its between the metal behind the batterie and the outer finder! If you take the head light out you can look through the wholes and see it. Its not worth it i promise!
Well I paid about 250ish from Seige Engineering over a year ago and yes they are very loud. My compressor and tank are no longer in my toolbox though. I cut a sheet of 1/8" SS at work and made a plate that goes in front of the radiator support and mounted the tank on the underside and the compressor on top. Thats 200lbs of air in a 3gal tank.
