EGR Valve replacement.
Old Aug 20, 2009 | 12:19 PM
racer60m's Avatar
racer60m
Default EGR Valve replacement.
Anyone had to change out the EGR Valve on a 2005 Ram w/Hemi? Do I need any special tools? Should I be aware of anything? Not going to let the stealer charge me $200 just in labor.
Thanks,
Chris
Old Aug 20, 2009 | 01:40 PM
chefred112's Avatar
chefred112
no..one of the easiest things to change...unclip tube by tb, remove 2 screws from tube to egr, unplug harness from egr, unbolt 2 screws holdin egr to head..that's it..
Old Aug 20, 2009 | 02:55 PM
racer60m's Avatar
racer60m
Sounds simple enough. Thanks!!!
Old Aug 20, 2009 | 04:04 PM
Horseapples's Avatar
Horseapples
pretty simple to change
Old Aug 20, 2009 | 05:46 PM
Hemi1500_600RR's Avatar
Hemi1500_600RR
I had an issue with mine and just cleaned it and everything worked like new. Might wannt try that before spending the cash. Its up to you though. Carb Cleaner does wonders!
Old Aug 21, 2009 | 05:52 PM
travisfimple's Avatar
travisfimple
I always had issues with mine in my 2004 ever since I installed headers. It went out almost immediately but it's an easy change as mentioned above. And only about $40 and 10 minutes worth of work. Then I always had an error code saying too low pressure reading. Seems my headers were sucking all the exhaust out and not letting enough through the little exhaust tube. It still ran good after I replaced it the first time but it was always a troublesome part. Just an FYI if you have aftermarked exhaust or headers.
Old Oct 27, 2010 | 09:16 AM
rodncher's Avatar
rodncher
Thanks Guys this was a big help found the part and fixed it myself in 10 minutes. Shop wanted to charge me 176.55 and i fixed it myself for 49.95.
Old Apr 12, 2011 | 01:50 PM
youngbuckman's Avatar
youngbuckman
Default A picture is worth a 1000 words. But the finger is priceless! Thanks
Old Apr 12, 2011 | 01:58 PM
SLT8's Avatar
SLT8
Offtopic-
Cood color choice for your valve covers ))
Old Apr 12, 2011 | 02:24 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Just so everyone knows, all you need is a 8mm and a 10mm to change it out
