Thud in Reverse
Old Aug 22, 2009 | 10:51 AM
kmroni79's Avatar
kmroni79
Default Thud in Reverse
I have a 2007 4X4 QC 1500. Just recently when in reverse, if I give it some gas you can hear a thud and it almost feels as if I ran something over. Also, I have noticed a slight vibration while in drive going from a stop. I just figured it was the tires starting to break loose since it seems to always be raining here. Any help would be appreciated, thanks.
Old Aug 22, 2009 | 12:00 PM
draco8494's Avatar
draco8494
might be your u joints going, when its not rainin climb under there and wigle the drive shaft and see if theres any play in them
Old Aug 22, 2009 | 12:33 PM
kmroni79's Avatar
kmroni79
U joints seem to be fine. I did notice some oil build up on the transfer case, I wiped it up and it looks to have some hairline cracks.
Old Aug 22, 2009 | 12:56 PM
draco8494's Avatar
draco8494
in the xfer case itself? usually those are casting marks that look exactly like cracks but you wiped it all clean so ull know if its leaking or not
Old Aug 22, 2009 | 01:05 PM
kmroni79's Avatar
kmroni79
Yes I wiped it a few days ago and the oil is slowly building up where the "cracks" are.
Old Aug 22, 2009 | 01:12 PM
draco8494's Avatar
draco8494
well thats not good! she still under warranty?
