differential question
Old Aug 24, 2009 | 01:59 PM
Douglas965's Avatar
Douglas965
Default differential question
How do I find out if my 2006 Dodge Ram SLT 4X4 has a limited slip differantial, without pulling the cover off. I am going to change the gear oil in the front and back diff. I see that it calls for an additive in the rear if it has a limited slip. I would prefer not to buy it unless I have to.
Old Aug 24, 2009 | 03:02 PM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
I think it is on a tag on the rear axle. I will move this thead to the third generation Ram section as they will help you,
FF
Old Aug 24, 2009 | 06:17 PM
98cherryram's Avatar
98cherryram
the sticker in your glovebox will tell you
Old Aug 24, 2009 | 07:23 PM
cheapbeater's Avatar
cheapbeater
^yep, sticker in glove box will say anti spin...
Old Aug 25, 2009 | 11:16 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Why not just go out in some grass of loose dirt and spin the tires for a sec to check and see?
Old Aug 25, 2009 | 02:13 PM
Douglas965's Avatar
Douglas965
I searched the rear end up and down. No tag or etch. Also I do not have any stickers in the glove box. ?
Old Aug 25, 2009 | 03:24 PM
chambers's Avatar
chambers
Request a build sheet from dodge online or at your local dealer.
Old Aug 25, 2009 | 03:49 PM
95_318SLT's Avatar
95_318SLT
Jack up the rear axle and spin one tire. If the other tire spins the same way, you have a limited slip diff, if it spins the other way, you have an open diff.
Old Aug 25, 2009 | 08:37 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Like I said, go out there and spin the tires in dirt and see if you have one track or two.
Old Aug 25, 2009 | 09:11 PM
lxman1's Avatar
lxman1
Site Moderator
Often in loose dirt, an open rearend will spin both.
Here is the easiest way tha always works for me.
Chalk the front tire, put the truck in neutral, jack up one rear tire.
Try to spin the wheel by hand, if it and the drive shaft spin, it is open, if it is locked like the brake is on, it is a LS and the clutches are keeping the axle from turning.
I can actually torque the lug nuts on my Ram and Mustang this way because the clutches work as they should.
