HIDs Have Arrived
Old Aug 25, 2009 | 10:35 PM
05DodgeRamHemi's Avatar
05DodgeRamHemi
Default HIDs Have Arrived
It was a pleasant surprise returning home from a long three days of clear cutting 5 acres of trees to see that my 8000k HIDs had shown up for my headlights and foglights from HIDxtra. Just wanted to ask you guys if there are any tips I should know before tackling the installation when I get a chance? I can't wait to put them in, my visibility just really sucks!
Old Aug 25, 2009 | 10:38 PM
SilverBullet08's Avatar
SilverBullet08
nice. it goes ballast, capacitor, factory harness. then connect the bulb wires. also do not touch the bulbs with your fingers. u will need a 10mm socket wrench to take out the three bolts on each headlights
Old Aug 25, 2009 | 10:39 PM
cheapbeater's Avatar
cheapbeater
do it yourself... dont let some dumass at a shop fu*k it up...
Old Aug 25, 2009 | 11:38 PM
Ridinhigh's Avatar
Ridinhigh
good luck on yours man my headlights work but the fogs dont even after i got them to work and installed them back in they still worked the shut it off for a couple hours took it out that evening and BAM didnt work at all so now I have to call to talk to there technition to see if I can get them working
Old Aug 26, 2009 | 12:35 AM
VP64's Avatar
VP64
let me know how u get your headlights off
Old Aug 26, 2009 | 09:47 AM
05DodgeRamHemi
Why, did you have a problem getting them out?
When I installed the smoked headlights, I just took out the plastic fender wells to get easier access to that pita bolt. I'm hoping it will be easier this time around since I'm accustomed to taking them out now.
Old Aug 26, 2009 | 10:22 AM
dirtydog's Avatar
dirtydog
Moderate User
You don't need to take the headlights off just to replace the bulbs.
Old Aug 26, 2009 | 12:45 PM
SilverBullet08
^ how would you get the bulbs out then? there is no room to get your hands in there w/o taking the headlights off. i became a pro out it and can get both of them off in 15 minutes now lol
Old Aug 26, 2009 | 01:49 PM
xfeejayx's Avatar
xfeejayx
3rd gen Ram, Newbies
you're right, but it's a biatch if you don't (I did that three times). The driver side light is just too much of a pain to replace the bulb. passenger side I wouldn't pull out just to replace a bulb.
With the right extensions (that I just bought a few days ago) I can get them out in about 5 minutes.
Old Aug 26, 2009 | 01:56 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
I never took mine out to replace the bulbs. I went under the truck and did it. Granted the drivers side is tight but it can be done. The pass side is very easy.
