Misfire problem
Old Aug 28, 2009 | 01:37 PM
HammerZ71's Avatar
HammerZ71
Originally Posted by dirtydog
Spray a can of silicone all over the engine while it's running.(plug wires & coil packs) This will isolate your problem. Your engine will surge once an open break or crack is found. It will make a mess, but once the problem is fixed, you can pressure wash everything clean(while your engine is running and stay off the alternator while sprayingwith water)
Good call 'dog, been years since I had to spray good old WD40 on the wires and boots to look for a hairline crack, but was used all the time back in the day...
