Projector headlights with halo
Old Aug 29, 2009 | 07:51 PM
donjohnk's Avatar
donjohnk
i bought some cheapos on the net and they were pretty nice... But I had adjust them to a spot you can actually see 10' past the truck and the projector itself is WAY off! Looked like crap, so now im looking to get either back to a after market stock headlight or find a better brand...
Old Aug 29, 2009 | 08:11 PM
xfeejayx's Avatar
xfeejayx
3rd gen Ram, Newbies
buy them.
Old Aug 29, 2009 | 08:13 PM
EJM05's Avatar
EJM05
well the website i gave you allows you to use HIDs. I have hids in mine. i love them they are the greatest.
Old Aug 29, 2009 | 09:21 PM
JOHNSN10's Avatar
JOHNSN10
That link u sent is the same headlights that are on ebay.
Old Aug 29, 2009 | 10:08 PM
EJM05's Avatar
EJM05
go for it then. buy the projector lights and then install HIDs in them. they are the perfect combo. check out my pics
Old Aug 30, 2009 | 12:23 AM
vipersforsale's Avatar
vipersforsale
to the OP... I have the exact same ones in my truck only difference is I bought them used for about $40 on ebay. And what was wrong with them was that the Halo LEDS had burned out and two of the other LEDs were out too. I just took them apart and replaced the clear Halo LED's with green ones and changed all 12(you only see that it has 10) of the other LED's to amber and wired them to my turn signals. I didnt change them to HID's but did put silver stars in them to brighten them up a bit. The pattern of the projector does take several times of adjusting them to get a good coverage but eventually you'll get it to where you like it.
Old Aug 30, 2009 | 01:38 AM
OklaHemi's Avatar
OklaHemi
buy them if that is the look you want. i have bought plenty of tails from ebay and one set of heads never any leaking problems.
Old Aug 30, 2009 | 03:56 PM
Shiloh 24's Avatar
Shiloh 24
Are all the one's shown in that link compatable with HID's or would you have to do alot of mod work?
Old Aug 30, 2009 | 04:31 PM
02Regcab's Avatar
02Regcab
There is no extra work for the HID cause it is a different Housing,, HID run at cooler operating temperatures. The difference is the aftermarket housing may need a different bulb size then stock. Stock is 9007 but the housing I use takes H1Bulbs. Even if it says on it you cant use HID's I bet you can..
Old Aug 30, 2009 | 05:09 PM
Shiloh 24's Avatar
Shiloh 24
So the HID is basically just a replacement bulb that is instead an HID instead of a projector? I'm confused, sorry if I'm gettin off the topic but I don't know much when it comes to headlights and HID's.
