Projector headlights with halo
Old Aug 29, 2009 | 02:44 PM
JOHNSN10's Avatar
JOHNSN10
Default Projector headlights with halo
THESE ARE ON EBAY FOR $135 SHIPPED. SHOULD I BUY THEM? I HAVE A BLACK TRUCK AND I WANT TO GO FOR THE ALL BLACK LOOK. ANY IDEAS?
http://cgi.ebay.com/ebaymotors/ws/eB...tab%3DWatching
[IMG]file:///C:/Users/johnsn10/AppData/Local/Temp/moz-screenshot-1.jpg[/IMG]
Old Aug 29, 2009 | 02:50 PM
dirtydog's Avatar
dirtydog
Moderate User
I want to say you get what you pay for, but in all honesty, 95% of aftermarket projectors are all made in China anyways.
They may or may not leak after a while. Once they do, heat them up to pull them apart and then just re-seal them. Otherwise, that's the only issue cheapo headlights have is the seal. otherwise. i would buy them.
Old Aug 29, 2009 | 02:56 PM
JOHNSN10's Avatar
JOHNSN10
How would these things start to leak? It shouldnt just happen for no reason
Old Aug 29, 2009 | 03:17 PM
dirtydog's Avatar
dirtydog
Moderate User
Yes they will happen for no reason. leaks occur from the cheap seals used. they also occur from lack of quality control! Pretty much that's all that there is to worry about with those. Fitment, all aftermarkets will be the same. Some minor gaps and a little persuasion for fitment.
You may never have a leak issue??? cards are in the air, but again, what do you expect for $135 to your door. i consider them throw-aways for that price. use'em until you have a problem and just buy new one's.
Old Aug 29, 2009 | 04:37 PM
dedogg's Avatar
dedogg
for that price I say get them you will probably have to add another 100 (give or take) for ones over the net.
Old Aug 29, 2009 | 04:49 PM
EJM05's Avatar
EJM05
http://www.k2motor.com/02-05-dodge-r...eadlights.html
try these. i bought mine from them and i have no leaks at all. but i have a 06
Old Aug 29, 2009 | 04:50 PM
Bigc9164's Avatar
Bigc9164
save the money and get HIDs
Old Aug 29, 2009 | 05:08 PM
JOHNSN10's Avatar
JOHNSN10
Cant i use hids with these headlights?
Old Aug 29, 2009 | 05:17 PM
jarhead03's Avatar
jarhead03
No you cant, or at least it said so on the set I got. Theyre cool lights but the rings only show up at dusk and night
Old Aug 29, 2009 | 06:44 PM
JOHNSN10's Avatar
JOHNSN10
Ok then whats my best option for black headlights that i can use hids in? Ebay sells black headlights that are stock but black inside. Id rather buy those then attempt painting mine.
