dodge ram weatherstrip
Old Aug 31, 2009 | 12:48 AM
loren kraker's Avatar
loren kraker
Default dodge ram weatherstrip
Hi newbie here. I have a 04 ram 4x4 quad and i bought this truck in March. I just noticed that my weatherstrip on the drivers door is ripped from the door opening and closing. I then went to the local Dodge dealer and looked at an 03 and 04 that they had on the lot and both of those also had the same thing going on. Anybody on here have this problem before with your truck????? Thanks
Old Aug 31, 2009 | 01:14 AM
hemipower05's Avatar
hemipower05
ya i have an 05 and wen im drivin down the freeway it sounds like i have the window cracked open (and its also really windy round where i live so its even louder). i think i heard if we brought it into the dealership they would fix it? is this true?
Old Aug 31, 2009 | 08:51 AM
Shiloh 24's Avatar
Shiloh 24
My 02 is really loud on the driver's side as well, I haven't looked to see if the stripping is ripped or torn but I have noticed that in heavy rain it even leaks water now. Mine's at the dealership now if they will fix it let me know and I'll have them get that done for me.
Old Aug 31, 2009 | 12:18 PM
vipersforsale's Avatar
vipersforsale
mine started ripping on the passengers side first about a year ago and the drivers side about 6 months ago... I asked the local dealership here and they basically said take a leap, its way out of warranty.
Old Aug 31, 2009 | 01:54 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
My drivers side door in the same, the top corner of the door kept catching and pulling on it until it finally tore. I hate dealerships and so I just put a piece of black duct tape over it. You cant see it when its closed and barely see it when its open.
Old Aug 31, 2009 | 04:10 PM
hemipower05
do any of u guys have the loud wind sound too? and if so how did u get it fixed?
Old Aug 31, 2009 | 04:24 PM
xfeejayx's Avatar
xfeejayx
3rd gen Ram, Newbies
it happens only when the wind gets ridiculous, only happened to me once or twice. you won't believe the fix. roll down your window, put your foot up against the inside door handle, grab the top of the door, and pull the MF in.
Old Aug 31, 2009 | 08:41 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
I dont get any wind or leaks so far so I cant help.
Old Aug 31, 2009 | 11:50 PM
Wanderer's Avatar
Wanderer
Angry
NOTE: Out of warranty, out of luck
TSB 23-049-05
Drip Rail Door Seal Torn
Date: October 12, 2005
THIS BULLETIN SUPERSEDES TECHNICAL SERVICE BULLETIN 23-008-04, DATED
MARCH 2 2004, WHICH SHOULD BE REMOVED FROM YOUR FILES. REVISIONS
INCLUDE THE ADDITION OF 2005 MODEL YEAR AND REVISED PARTS.
Models: 2004 - 2005 (DR/DH) Ram Truck
Overview:
This bulletin involves replacing the secondary door seal with an improved seal.
Symptom/Condition:
The drip rail or secondary door seal may become torn from contact with the lower “A” pillar of
the front door.
Diagnosis:
Inspect the secondary door seal. If the seal is torn, perform the Repair Procedure.
Parts Required: Qty. Part No. Description
1 55277188AB Secondary Door Seal - Standard Cab -Right
1 55277189AB Secondary Door Seal - Standard Cab - Left
1 55277190AB Secondary Door Seal - Quad Cab - Right
1 55277191AB Secondary Door Seal - Quad Cab - Left
Repair Procedure:
1. Remove the secondary seal from the retainer (Fig. 1).
2. Install the new seal using the appropriate seal listed in the Parts Required section
above.
Policy: Reimbursable within the provisions of the warranty.
Time Allowance:
Labor Operation No: Description Amount
23-51-08-95 Install Secondary Seal, Both Doors 0.2 Hrs.
Failure Code:
ZZ Service Action
Old Sep 1, 2009 | 12:16 AM
loren kraker
Thanks Wanderer, thats what i was looking for. I noticed that the 08 has a different seal ,maybe i will see if that seal will fit. Its a lot more narrow at the a pillar and don't catch the door. I have no wind noise or water leaks its just annoying. Thanks Loren
