cam position sensor
Old Sep 1, 2009 | 10:48 PM
my 4.7's Avatar
my 4.7
Default cam position sensor
I have replaced the cam position sensor 3 times and the code still comes up about 3 to 5 days later!!! I have also replaced the computer and crank position sensor what should i do ?
Old Sep 1, 2009 | 10:51 PM
Mega-Hemi's Avatar
Mega-Hemi
Check the harness for corrosion, may be messing with your sensor readings. That and check the harness for any loose plugs or wires in the back of the plugs.
Old Sep 1, 2009 | 11:03 PM
my 4.7's Avatar
my 4.7
thank you for the reply i have checked all the conections and wire harness and the dealer cant find the problem, the only thing i can think of is that the oil im suppost to use is a synthetic blend but the last time i changed the oil i used full synthetic, can that cause a problem with the cam position sensor ????
Old Sep 1, 2009 | 11:18 PM
Mega-Hemi's Avatar
Mega-Hemi
I wouldn't think so, but stranger things have happened.
Old Sep 1, 2009 | 11:40 PM
my 4.7's Avatar
my 4.7
thank you for your time its just driving me crazy
