Vibration Under load?
Old Sep 6, 2009 | 09:05 PM
truckernate's Avatar
truckernate
Default Vibration Under load?
I have a 2002 dodge 5.3 4X4 Quad cab, It's all stock other then the leveling kit, I have just startd to get a constant vibration felt through the steering wheel only when under load(on acceleration) and it dissappers when i let off the throttle, the vibration is no worse at varying rpm's or speeds. I thought I may have threw a drive shaft weight, but no. Cultch fan is not locked up. and all the fluids are new. I don't mind it but it drive the wife nuts. Any Ideas.
Old Sep 7, 2009 | 12:36 AM
lxman1's Avatar
lxman1
Site Moderator
5.3? I am thinking 5.2 or 5.9???
I would check the plugs, wires, cap and rotor. May be misfiring under load.
Old Sep 7, 2009 | 04:16 AM
truckernate
Sorry,Don't know where i was.It's a 4.7, and there is no vibration in park at higher rpm and in drive with the brake on at higher rpm,only in motion.Going to remove the rear axle,drop it into 4 wheel and see if the vibration is still there to eliminate the rear end and drive shaft.
Old Sep 7, 2009 | 09:53 AM
dirtydog's Avatar
dirtydog
Moderate User
Have you checked the u-joints?
Old Sep 7, 2009 | 01:16 PM
truckernate
I have checked the u joints,front cv shafts ,front drive shaft ball joints(not related) What about torque converter/fly wheel.
Old Sep 7, 2009 | 01:30 PM
lxman1's Avatar
lxman1
Site Moderator
You may not feel the ignition miss in park or at high rpms, they are usually most noticable @ lower rpms under a load.
Could also be in the driveline.
Old Sep 7, 2009 | 01:42 PM
Sixtysixdeuce's Avatar
Sixtysixdeuce
That'd be my thought, if the vibration subsides when the brake is applied. Applying the brake takes the TC out of lock-up.
On the same note, a light misfire is also greatly amplified through the drivetrain when the TC is in lock-up.
Scan for misfire codes first, then physically inspect ignition components. If there's any doubt, do a full tune-up. Plugs, wires, cap & rotor are a whole lot cheaper and easier than a converter.
Old Sep 7, 2009 | 07:21 PM
Lifted4x4Astro's Avatar
Lifted4x4Astro
Originally Posted by truckernate
I have checked the u joints.
How did you check them? If you didn't pull the driveshafts, you didn't check them properly. You very well could have a sticky u-joint. You have to pull the shafts and be able to freely rotate the joints...simply can't be done on the truck.
