New Tow Hooks (2005 1500) "Blah Mopar"
Old Sep 10, 2009 | 11:48 PM
Mike Jazz's Avatar
Mike Jazz
Default New Tow Hooks (2005 1500) "Blah Mopar"
Well, I decided to not go with the standard Mopar tow hooks for the 1500, so I opted to make some of my own. These were simply made with 1/2" steel plates welded to a set of 12" receiver tubes that were cut down. Once welded, they were bolted to the front of the frame horns with the existing 4 bolt holes that were there. Another piece of 1/2" steel was used as backing plates as added protection with the grade 8 hardware already used. I pondered this idea for a while, since I had a similar setup on my Blazer ZR2. This is much stronger than that setup, so I know it will hold plenty. Here are the crappy pics.
Old Sep 10, 2009 | 11:55 PM
Jarrod904's Avatar
Jarrod904
those look like some knee knockers! haha good setup tho
Old Sep 11, 2009 | 12:03 AM
Mike Jazz's Avatar
Mike Jazz
Thanks. They stick out a hair, but I wanted to be able to take them out whenever I wanted to. Never had a problem with them on my ZR2, so this setup will definitely be an improvement over that. Just wanted the function aspect of it.
Old Sep 11, 2009 | 12:06 AM
Jarrod904's Avatar
Jarrod904
ohh i just noticed you can take them off.. thats a pretty sweet idea
Old Sep 11, 2009 | 12:40 AM
HammerZ71's Avatar
HammerZ71
Good job... I basically lost my tow hooks when the grille guard and winch mount went on, so I drilled a couple holes in the winch mount plate and put in a couple grade 8 U-bolts. Connected a couple clevis' and had my anchor points back...
Old Sep 11, 2009 | 01:45 AM
vipersforsale's Avatar
vipersforsale
Originally Posted by Mike Jazz
Well, I decided to not go with the standard Mopar tow hooks for the 1500, so I opted to make some of my own. These were simply made with 1/2" steel plates welded to a set of 12" receiver tubes that were cut down. Once welded, they were bolted to the front of the frame horns with the existing 4 bolt holes...
Make more, market/sell them, get rich...
Old Sep 11, 2009 | 03:29 AM
Hoss356's Avatar
Hoss356
I'd but a set for 30 bucks...
