camshaft
Old Nov 30, 2009 | 10:23 PM
  #21
Off_Road_Teacher's Avatar
Off_Road_Teacher
Originally Posted by blackbetty696
what would be a good cobination of cam and roller rocker arm ratios and springs and rods for what i am trying to do?
What type truck are you, 2wd or 4x4. Do you care about having trans control or are you fine with the stock shifting? Are you going to race the truck or just want more power for daily driving. Basically I need a little more info about your truck and what you want to do with it before I can tell you what cam will work best for you. I know you are looking for a big cam so I have a couple in mind, just depends on what you are planning on doing with your truck.
Old Nov 30, 2009 | 11:06 PM
  #22
chefred112's Avatar
chefred112
here is how my cam sounds... my quickest 1/4 to date is 13.08... do a search on youtube for chefred112 to see my vids..
http://www.youtube.com/watch?v=tmskQNkx-nA
http://www.youtube.com/watch?v=DA_MFYFOPCI
http://www.youtube.com/watch?v=szjNiZyVJVw
racin an rc srt10
http://www.youtube.com/watch?v=PSB_VuN5OKY
Old Nov 30, 2009 | 11:26 PM
  #23
chefred112's Avatar
chefred112
Originally Posted by RamIt33
If you are looking for some performance parts for your hemi check this site out. I was looking at the cams here on this link, the hemi street cam is the way i am going to go.
http://www.fasthemis.com/index.asp?P...S&Category=566
that is a really mild cam...if you want an aggressive (and pcm friendly) cam. Check out inertiamotorsports.com , the fastest (1/4) na stock block qc that I know of has the same cam I do... talk to Stu..he can custom grind an aggressive cam that can be pcm friendly..
Old Dec 1, 2009 | 08:23 PM
  #24
blackbetty696's Avatar
blackbetty696
i am a 2wd i would like to eventually convert to a manual transmission so i guess stock would be fine for now and i drive it every day so daily driving but i would like to show up at the local drag strip and send them all home crying!
Old Dec 3, 2009 | 04:11 AM
  #25
RamIt33's Avatar
RamIt33
Since we are on the Cam subject, the cam i was looking at is just a basic cam?? What would be good one to fit my truck??
I alternate my truck with my car so i use it 50% of the time. Never been to the drag hopefully next summer. Just want it to have the extra power to keep up with the Tundras. I have a 4X4 QC Big Horn Edition....
Old Dec 3, 2009 | 09:04 AM
  #26
truckin151's Avatar
truckin151
Start upgrading other things and save the cam for a little while. The bigger the cam you go the more supporting mods you are going to need to really take advantage of it.
Old Dec 5, 2009 | 05:45 PM
  #27
blackbetty696
other than springs what else would i need?
Old Dec 5, 2009 | 06:10 PM
  #28
Off_Road_Teacher
Pushrods, the tools to install the cam, and a tune depending on what cam you use.
