Problem at exhaust shop
Old Sep 14, 2009 | 06:09 PM
Toefur's Avatar
Toefur
Default Problem at exhaust shop
Well..I went to get my CB Extreme SI/DO muffler installed today. I told the guy I wanted an exit behind each wheel with 4" slash cut tips. They put my truck up on the lift and he comes back and says the only way he can get an exit to the driver side is to run a pipe across the back of the differential. So, if your looking at the back of my truck it would have a 2.5" pipe running across the rear end to the driver side...I dont think I can deal with looking at that so I said forget it. I know some of you have this set up..is this how yours is done? Ill run em straight out the back if I hafta but I wanted to be a little different from most of the Rams I see around here.
Old Sep 14, 2009 | 06:15 PM
truckin151's Avatar
truckin151
Thats how my old cat back was ran, you couldn't see it from the back (unless yours is lifted then you may be able to).
Old Sep 14, 2009 | 06:22 PM
travisfimple's Avatar
travisfimple
I had true duals with side exits on my old 2004 hemi sport quad cab. Sounds to me like your exhaust guy is lazy and wants a bolt on solution instead of bending a couple tubes. My neighbor just bought it from me so let me know and I could go take some pics under the truck if you wanted to see how it was run.
Old Sep 14, 2009 | 06:38 PM
Toefur's Avatar
Toefur
Travis, that would be awesome!
Old Sep 14, 2009 | 07:00 PM
bwhite757's Avatar
bwhite757
That's BS, I have the same setup. The driver's side exit pipe goes up and over the driveshaft, then crosses over the rear axle on the driver's side, and then bent behind the wheel.... (Granted I had to have it redone as he didn't put it quite high enough over the driveshaft the first time and I was scrubbing it when I was towing).
The end result:
Old Sep 14, 2009 | 07:22 PM
EJM05's Avatar
EJM05
This is what I got.
Old Sep 14, 2009 | 07:39 PM
draco8494's Avatar
draco8494
well i got duped... mines run like the OP is describing...and i dont really like it...luckily i want something diff so it doesent matter
Old Sep 14, 2009 | 08:27 PM
disturbedgator's Avatar
disturbedgator
i had the same muff and setup but the muff guy curved it in front of the pumpkin and it crosses the driveshaft on the drivers side. but not anymore thanks to a creek crossing
Old Sep 14, 2009 | 09:53 PM
dedogg's Avatar
dedogg
yep your guy is full of **** I have true duals and they dump right after the rear axel on both sides of the spare tire.
