Oil Pressure ??
Old Sep 15, 2009 | 05:45 PM
cheapbeater's Avatar
cheapbeater
Default Oil Pressure ??
So my brother took me for a ride in his 03 GMC Sierra with the 5.3 the other day, and when he floored it, it would peg the oil pressure gauge (at about 5500 rpm)
My oil pressure gauge moves very little if any... it hits half when i start it, and stays there till i shut it off.
So is this how your Hemis are?
Anyone know why my bro's truck pegs the gauge?
Old Sep 15, 2009 | 05:53 PM
lxman1's Avatar
lxman1
Site Moderator
Bad GM ground, which is pretty common. It could also be a bad sending unit. On the Obama Motors truck.
Yours may be a dummy gauge that reads about 1/2 as long as you have over 7psi of pressure.
My 08 goes up to almost 3/4 when cold and at higher rpm and at a hot idle about 3/8. It works as a real gauge.
Old Sep 15, 2009 | 09:22 PM
cheapbeater
so the problem is with his truck, not mine? i thought that 5.3 was gunna start spraying oil with all that pressure. lol.
maybe mine is a dummy gauge... anyway to check?
Old Sep 16, 2009 | 01:19 AM
abarmby's Avatar
abarmby
Yours is an 03 like mine. Dodge use a dummy type gauge in our trucks.
If it's got oil pressure, it'll read a lil' past halfway.
Mine has always been like this.
Al.
Old Sep 16, 2009 | 02:36 AM
PETE_YK's Avatar
PETE_YK
Just outta curiousity, what psi was it showing when it was pegged?
Old Sep 16, 2009 | 05:48 PM
lxman1's Avatar
lxman1
Site Moderator
I know the GM's usually hold about 40psi Hot. Up to 62psi cold.
We used to have a Chevy Astro van years ago. It always read 80psi until I put a new sending unit in it, then it stayed between 25 and 40 like it should.
Old Sep 17, 2009 | 08:27 AM
V10Venom's Avatar
V10Venom
Dodge's oil pressure gauges are Dummy gauges. They sit in the middle and look pretty.
Old Sep 17, 2009 | 06:49 PM
lxman1's Avatar
lxman1
Site Moderator
Mine doesn't!!
