I need it louder!!!!
Old Sep 15, 2009 | 10:15 PM
  #31
EJM05's Avatar
EJM05
wait so i need to get the 3" tube?
Old Sep 15, 2009 | 10:19 PM
  #32
dedogg's Avatar
dedogg
It depends on where you are gonna put it, but like teach said if it is after the y pipe it should be 3"
Old Sep 15, 2009 | 10:20 PM
  #33
EJM05's Avatar
EJM05
yea before the muffler. but from the cats back i have all new piping from the exhaust guy. so ill have to find out what size it is.
Old Sep 15, 2009 | 10:22 PM
  #34
dedogg's Avatar
dedogg
yes you will. lol
Old Sep 15, 2009 | 10:30 PM
  #35
EJM05's Avatar
EJM05
Sweetness. Its a done deal. Im figuring out which size I need then Im going to order it. Then install it. (DUH) and then put up a video it.
Old Sep 15, 2009 | 11:40 PM
  #36
truckin151's Avatar
truckin151
Definitely make sure you verify the length of cable, they sent me 10ft I think and it was about 10ft to short (and thats on a regular cab!!), you'll be surprised how long of cable you really need.
Also the cig lighter was a PITA to get out and away from the plastic ring its mounted in if you decide to reuse it. Other than that though the installation was a breeze. One thing to remember about them though is that you cannot shut them at high rpms and opening them at high rpms (over 1500 I believe) can slap them open, both way will burn the motor out and cause it to slip.
Old Sep 15, 2009 | 11:48 PM
  #37
truckin151's Avatar
truckin151
Just thought about this, if you want it a little louder idle you can also see about throwing some LT's in there, they change the note of the exhaust a bit as well
Old Sep 15, 2009 | 11:49 PM
  #38
OklaHemi's Avatar
OklaHemi
after teach's video i want one. i miss the way mine sounded with no cats. but all the time was too much and i added a res to quiet her down. but sometimes you need to scream
Old Sep 16, 2009 | 12:58 AM
  #39
Ridinhigh's Avatar
Ridinhigh
man you all are wasting your money lol I just cut the exhaust after the Y pipe for my cutout and I love it The look on some peopls faces when I floor it is awesome and also lets them know to stay out of the way but it has a great idle and doesnt really bother me on the res in the cab
I have taken a couple 3 hour trips with it and it is not that bad and people have been able to sleep in side of the truck while driving on the highway but they stirred a little but when it would down shift going up a hill or passing someone
I will try to get up a video in the next day or 2 to let you listen to it and if you get anxious just cut the pipe ahead of time to get a sample of how it sounds
Old Sep 16, 2009 | 07:33 AM
  #40
The Bull's Avatar
The Bull
Originally Posted by Off_Road_Teacher
Very easy. Pulled out the cigar lighter, removed the wires from the lighter and hooked them to the switch, put the switch in the lighter hole (it fits almost perfectly) then run the cable to the cutout motor.
How did you get your lighter out? I tried for about 1 hour and it wouldt budge
