O3 Ram AC compressor issue
Old Sep 21, 2009 | 09:48 AM
Rob B's Avatar
Rob B
Default O3 Ram AC compressor issue
Went out this morning to find the bearings (assuming) in the ac compressor clutch is basically going south real quick. Also noticed Saturday night that the air wasn't working either. Is there a replacement belt I can put on for now to bypass the AC unit until I get a chance to replace the compressor?
Old Sep 21, 2009 | 10:35 AM
V10Venom's Avatar
V10Venom
Just unplug that A/c, it will just let it free spin.
Old Sep 21, 2009 | 10:59 AM
dirtydog's Avatar
dirtydog
Moderate User
bearings going on your A/C compressor along with no A/C means low on fluid and mainly OIL. There is supposed to be an exact mixof oil/freon in there. No oil=burnt up a/c compressor.
Old Sep 21, 2009 | 04:55 PM
lxman1's Avatar
lxman1
Site Moderator
If the clutch bearing has failed, then I think you are going to have a hard time bypassing the compressor. I haven't really paid attention to the belt routing on the 03.
Old Oct 4, 2009 | 01:44 AM
Veibz's Avatar
Veibz
I feel like I have been on here quoting prices for radiators and ac compressor kits all night haha. Oh well I am bored.
Complete AC Kit for the truck. NEW compressor, O-ring kit, Drier/accumulator, expansion device....
2003:
5.7L $212 for the whole kit
4.7L & 3.7L $199
Old Oct 4, 2009 | 02:21 AM
lxman1's Avatar
lxman1
Site Moderator
Sounds about right. Then you will need the proper amount of oil and freon.
Vacuum the system down to at least 29" of vacuum before charging.
Old Jan 5, 2014 | 06:09 PM
Slayr's Avatar
Slayr
Default 4.7 AC Compressor Bypass
You need to either move the compressor out of the way...or remove the pulley from the compressor (don't forget that snap-ring before you use the puller) Then you have to make sure the belt runs all the accessories the correct direction....or you are just going to cause more damage (like spinning out the water pump). The belt you need for the 4.7L is originally 88" long. you will need to go with a 6 tooth 83" belt (Advance Auto). It is a snug fit at first (5" smaller than stock)...found it to be easier to slide it on to the water pump...instead of tying to get it up over a pulley lip. The job actually took me 4 hours to do. So allow time to do so. Hopefully the picture will help answer any unanswered questions.
Old Jan 5, 2014 | 07:36 PM
Prismatic's Avatar
Prismatic
Neat info
Old Mar 12, 2018 | 02:18 PM
dented's Avatar
dented
Your post and photo saved me a ton of time, frustration, and all likelyhood, money. Thanks. I know this is a old thread, but I wanted to register and post to make sure people know that it mattered to somebody. Keep up the good work.
Old Feb 7, 2019 | 03:43 PM
Sean Sanford's Avatar
Sean Sanford
Default Re a better way to route belt
There is a better way to route belt
Last edited by Sean Sanford; Feb 7, 2019 at 03:45 PM. Reason: Reply in wrong place
