2006 Dodge 1500 2WD lift help!
Old Sep 21, 2009 | 09:46 PM
meltorres's Avatar
meltorres
Default 2006 Dodge 1500 2WD lift help!
I currently have a 2006 dodge 1500 2WD that I want to put a 6" to 7" lift on plus a 3" body lift later. I was wondering if anyone know what the cheapest way to do this yet not have a crappy ride to the truck at the same time. If anyone has any suggestions or truck that they have with lifts that are 2WD please post it on here so I can see whats out their. also include what you paid total.
Thanks,
Ethan
Old Sep 22, 2009 | 12:47 AM
OlDirtyJohn's Avatar
OlDirtyJohn
really the ONLY way you can achieve that is with a 3" lift spindle, and a 3" poly spacer. then you could do a body lift on top of that. check out www.topguncustomz.com , they will have everything you need for that kind of a project.
what size tire are you planning on running after that kind of a lift? you do realize that running huge tires on the 2wd suspension is going to stress it out alot, and possibly cause parts to fail prematurely, right?
