need help locating brothers!
Old Sep 26, 2009 | 11:12 PM
EJM05's Avatar
EJM05
Not sure if this helps. But its a 3" suspension lift I think.
http://www.dieseltruckresource.com/d...t124022p3.html
Old Sep 26, 2009 | 11:30 PM
santafehemi's Avatar
santafehemi
Originally Posted by ramhunter9
its on a 2500 frame and suspension called the heavy half it comes from the factory leveled i guess because she is level as hell.
and im not going to do a body lift im replacing springs front and rear . fronts im getting
3" springs and rear im getting 3" leafs.
having a solid axle rig now is awesome and cheap to lift. the ol red one was IFS and $$$
3" should do me fine for now because i want to keep my tires i have now.
the pic you sent over looked like a body lift same height as the suspension lift and it had factory tires so thats what it may look like
ya i hear you when is started to look for lifts for my truck it pissed me off how much cheaper the 2500 lift's were
Old Sep 26, 2009 | 11:43 PM
ramhunter9's Avatar
ramhunter9
well its not the 2500 thing its the solid axle thing
the IFS you have is just expensive trust me i no you seen my old truck
Old Sep 27, 2009 | 12:24 AM
OklaHemi's Avatar
OklaHemi
from what i could gather these all have 2.5-3" lifts. the first one is on stock 285's
hope these help ya
Old Sep 27, 2009 | 12:51 AM
disturbedgator's Avatar
disturbedgator
i know this doesnt help but i say screw lifting it get new wheels and tires. makin it have a wider stance would look awesome.
Old Sep 27, 2009 | 11:32 AM
ramhunter9's Avatar
ramhunter9
nah i like the wheels and tires on her now plus ther brand new so i thin a 3" lift is a good way to start. for only 200 bucks i can get 3" suspension. not bad later down the road when tires go south ill do 35's and do a bit more on the lift . im lovin the solid axle cheap and easy.
thanks for all the pics brothers OL RH thanks ya
Old Sep 27, 2009 | 12:36 PM
lxman1's Avatar
lxman1
Site Moderator
The 265/70 17's that were on my 01 F150 were about 31.7" tall.
Yes, most 275/60R20's are 33" tall.
275mm wide/ 60% as tall as they are wide (aspect ratio) 20 (obviously rim diameter).
265/70R17 = 265mm wide/ 185.5mm from rim to tread,on 17" wheel = 31.6" tall
185.5mm(7.3") x 2 + 17=31.6
Each tire manufacturer will vary a little. Confused yet??
Old Sep 29, 2009 | 11:53 AM
CRAIG02RAM's Avatar
CRAIG02RAM
Ramhunter9 post a pic when you get her lifted up. and how much did the 3 inch lift cost?
Old Sep 29, 2009 | 01:54 PM
ramhunter9's Avatar
ramhunter9
lift and new shocks 350
Old Sep 29, 2009 | 02:12 PM
SilverBullet08's Avatar
SilverBullet08
i think they will look small
