Need tires that last longer then a year
Old Oct 1, 2009 | 08:00 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
If I went through a set of tires in a year I would be checking my driving habits (driving around corners), my tires air pressure and alignment.
Old Oct 1, 2009 | 08:03 PM
BEAR's Avatar
BEAR
I have Mickey Thompson BAJA ATZ'S. I got them almost 2 years ago. I rotate them religiously every 6K miles and I have just done my 4th rotation and they still look like new.
Old Oct 1, 2009 | 08:10 PM
nim81's Avatar
nim81
my father has some Michelin a/t's on his truck and he's gotten 80k and there is still tread on em.
my bridgestone dueler revo's are looking pretty bad after 25k
Old Oct 1, 2009 | 11:35 PM
lxman1's Avatar
lxman1
Site Moderator
BFGoodrich Long Trail T/A's have the longest tread life rating in that size. I'll be getting them when My OEM Badyears wear out. (already @ 20K and have plenty of tread left).
You need better than OEM shocks and an alignment as well.
http://www.samsclub.com/shopping/nav...=5&item=396647
Old Oct 2, 2009 | 05:49 AM
abarmby's Avatar
abarmby
I have 275 60 R20 Cooper Discoverer HT+ and have over 33K on them.
They still have about 3mm left of tread and I rotate them every 6-8K.
I also run at 38-40 psi.
To the OP, If ramhunter9 is correct and your getting 60-70K miles out of yours, your doing very well imho.
Al
Old Oct 2, 2009 | 07:18 AM
Pirata's Avatar
Pirata
From: 2nd star to the right, then straight on until morning
The stock tires I had 40000 miles on before I switched to my BFG's and my stock tires still have another 10000 - 15000 miles left on them. How many miles are you doing in a year? How fast are you driving?
Old Oct 2, 2009 | 07:36 AM
HammerZ71's Avatar
HammerZ71
You'll get much longer life from the "soccer mom" type tires, like the BFG Long Trails, Firestone Destination, etc. Very good road characteristics from both of those tires and 60-80k life is not uncommon...
Old Oct 2, 2009 | 07:47 AM
dodgenitto's Avatar
dodgenitto
Originally Posted by andy713
I was running 37x13.50R20 toyo MT's. That was the best tire i've ever owned. I think i got 15 or 20k out of them.
That's not very good. I have 37x13.5R20 Nitto Mud Grapplers and I have 60,000 on them and still going. If I only got 20K I would be pissed. Heck they come with a 40,000 mile warranty.
Old Oct 2, 2009 | 09:06 AM
nim81's Avatar
nim81
if you live near a plaza tire, and get really tiny tires, they will replace them for free when they wear out as long as you have the same car. they call it the "forever tire"
Old Oct 2, 2009 | 10:12 AM
dirtydog's Avatar
dirtydog
Moderate User
Originally Posted by Riccs22
i only drive about twelve thousand miles and they get worn out and its not like the front last much more then the rear and i dont think they make the cooper zeon ltz any more i looked on tire rack and they dont have them
Discount tire direct has the best pricing on the Cooper LTZ's at 177$ shipped to your door per tire. Treaddepot is 2nd. $179 after shipping.
Stock wrangler HP tire is garbage and has terrible rain characteristics; however, they are ade for highway and do last 30-40kmi if only used on the highway.
You need to keep a few thing in mind. Are the roads rough? Are you driving on concrete where it has the water grooves or traction grooves cut into the ground? rough roads wear tires faster. grooved concrete roads EAT tires alive! If you constantly turn the wheel full lock while sitting still, that attributes to tire wear. if you tow and have an LSD, that attributes to tire wear. last but not least, tire pressure.
This is not even going over the aggressive styles that aid in tire wear which you said you weren't aggressive so the above forementioned still would apply to you.
Cooper LTZ has exceptional road manners for the big blocks of tread it has. Zero road noise so far and I've been running them hard for 5kmi. Excellent water tire!
Prob not the best All highway tire. I would say the BFG Long trail and other tires that have smaller tread blocks is what you should be looking for.
