RPM Surge answers?
Old Oct 1, 2009 | 09:47 PM
A-10 KChawg's Avatar
A-10 KChawg
Default RPM Surge answers?
2002 RAM 1500 QC 5.9...... I just bought the truck not too long ago. I tested the cruise to make sure it worked, etc. Well I finnally used it for a longer distance today. THe RPMs seem to surge with Cruise engaged but only a couple hundred RPMs. THere is no sliiping in the tranny as I can feel the accelleration. I searched previous threads with tons of suggestions but never really gathered any outcomes of what the problem actually turned out to be. Anybody have any answers?
Old Oct 1, 2009 | 10:03 PM
PyRoHAvoC's Avatar
PyRoHAvoC
sounds like your TPS
1.) recalibrate
if that doesn't work
2.) take it off drill a tiny hole and hit with some radio shack contact cleaner ... let dry and seal with silicone
3.) replace it (like $30 or so at vato zone)
probably wasn't the TPS ... hahahaha
for me this was happening at idle ... did the recalibration and it took care of the problem
Old Oct 1, 2009 | 10:13 PM
nim81's Avatar
nim81
dont drill a hole in your tps.
check the voltage on it. use a multimeter on the middle wire to the tps, key on engine off. should be close to .7v if not then it might not be bad but might need adjusted.
if it needs adjusted i will do a lil write up for ya. common on the magnum engines
Old Oct 1, 2009 | 10:16 PM
kah1010's Avatar
kah1010
what speed you were driving when you had surge?
my 4.7L -08 sometimes has sometimes (surge) problems when trying to maintain ~30mph (about 1,000RPMs).
In my city, the fine representatives of Department of Public Safety like to "welcome" you on 30mph zone with a ticket, thus safest bet has been to use cruise control....
K
Old Jun 2, 2010 | 07:24 PM
rbrumm's Avatar
rbrumm
Sorry to bring back an old thread but my '02 5.9 just started to do something similar only it seems to for a brief moment jump out of OD and then back in. I hope it isn't thew PCM again!!! I am going to try a reset...fingers crossed!
Old Jun 2, 2010 | 08:27 PM
nim81's Avatar
nim81
might need to adjust your tv cable from the TB to the tranny search 2nd gen ram
Old Jun 2, 2010 | 09:27 PM
nh5's Avatar
nh5
+1 mine does the same all the time. I don't even bother with the tv cable anymore cause its always off by a hair. Also I didn't think the recalibrate worked on our trucks cause we aren't drive by wire.
Old Aug 15, 2011 | 10:10 PM
rbrumm's Avatar
rbrumm
Still an old thread, I know but why start a new one...anyway, what I have noticed in a year is that on a really rough road with my heel on the floor and rest of the foot on the pedal, the truck will come out of "torque lock" and right back in. Kinda like a quick downshift. Is that the TV cable or something else? Like noted above, my truck will do this with the cruise on. Sometimes on a flat grade, but more often just cresting a hill when the accelerator is adjusting to the slower speed then back to cruising speed. Takes like a half a second then back to "lock".
