Gas Gauge Issue
Old Oct 5, 2009 | 02:16 PM
Shiloh 24's Avatar
Shiloh 24
Default Gas Gauge Issue
I noticed yesterday when I filled up that my gauge didn't read that I put any fuel in and after about 5 minutes it slowly started to rise. I don't know what would cause this. It has done this before and then it stopped but now its happening again.
Old Oct 5, 2009 | 03:55 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Ive seen it happen on mine once or twice. Usually i can cut the engine off and back on and it will begin to register the new level of fuel. IDK why though.
Old Oct 5, 2009 | 04:55 PM
dirtydog's Avatar
dirtydog
Moderate User
I know my old truck did that quite often. I found out later that the ground strap for the bed was broken. I replaced it and never had any issue's after.
Old Oct 5, 2009 | 06:14 PM
nim81's Avatar
nim81
happens to me once a month maybe. turn truck off and back on. works great again.
will check my ground... didnt even think about that.
like the new sig dirty!
Old Oct 5, 2009 | 08:06 PM
berndog67's Avatar
berndog67
yeah its def the bed grounding strap, mine had the same thing happen like three fill-ups in a row, and someone from work said to just turn it off and turn it back on, and yes its a quick fix, but i happened to be putting on my new dual exhaust and noticed the grounding strap in two pieces just dangling, so i replaced with a nice heavy gauge wire you would use for wiring up a battery, and left a little extra so it could flex, and no problems since!
Old Oct 5, 2009 | 09:10 PM
Shiloh 24's Avatar
Shiloh 24
That must be it, when I took the grandpa boards off I let it dangle cuz I didn't know wtf it was. I figured a ground but my tailights worked with it unhooked so I just said screw it. I'll go reattatch it.
Old Oct 5, 2009 | 09:31 PM
Shiloh 24's Avatar
Shiloh 24
I think this might be my issue
