3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
You guys are on a roll! Keep the jokes coming... I especially liked the ones about 'roadkill' and 'lift kits.'
I would check your shocks. How many miles are on them? Are they the originals? Also try different tire pressures. I know when I have 40psi in the back vs 35psi, its makes a HUGE difference to the ride quality. I usually lower them in the winter months because the roads here in Michigan buckle so bad.
Stocker shocks are terrible. I've had sandbags in the back of my truck since about a month after I got her... Haven't thought of it until recently, but my shocks are starting to give out now....
if u do decide to get a fat chick in the bed make sure to upgrade to the tow mirrors. it must be impossablle to see through the fat and jelly and through the fat, not to mention the fat.
they might punch a hole through your bed and start drinking your fuel
You insensitive gas bags, I resemble those remarks. I look for a little help and you tell fat jokes. I should take all of you redneck bubbas and throw you in the back and see how you like it!
i couldnt afford the tow mirrors when i put my bigger lady in the back so i just gave her a walkie talkie and she tells me when im clear to get over and how much farther back i can go
This. Not only do you have a smoother ride you now have blind spot monitoring and a rearview camera. Those are some luxury car options you got going now.
