What size nut?
Old Oct 6, 2009 | 07:15 PM
Muppet's Avatar
Muppet
Default What size nut?
I have bad wheel bearings, and of course they have to be $230 each.
I need to know what size the nut is on the end of the shaft, it is a 04 1500 5.7 with ABS in the front only.
Also any other cheaper options? I know most of the cost is comeing from the ABS sensor that is attached to the assembly.
-Nick
Old Oct 6, 2009 | 07:35 PM
Stainlesstig2's Avatar
Stainlesstig2
If your talking about the CV shaft nut, its a 36mm.
Old Oct 6, 2009 | 07:38 PM
Muppet's Avatar
Muppet
Perfect thanks!
Old Oct 6, 2009 | 10:20 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
You guys must be talking 4wd when you say 36mm because the 2wd I know isnt that big.
Old Oct 6, 2009 | 10:42 PM
big guy's Avatar
big guy
My 03 is 35mm. You can get OEM Mopar Hubs on ebay for under 100 bucks.
Old Oct 6, 2009 | 11:35 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Im just curious how you guys know he has a 4wd and not a 2wd?
Old Oct 7, 2009 | 07:51 AM
Muppet's Avatar
Muppet
It is 4wd
Old Oct 7, 2009 | 08:19 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
And so if you are going to stick around it would be good to add all that info in your profile.
x2 on buying them on ebay BTW.
Old Oct 7, 2009 | 08:32 AM
motorhead426's Avatar
motorhead426
ABS in the front only? Was that because of the year? Or the model? My 2005 has 4 wheel ABS, and I thought they all had that in 2005... did they change from 2004 to 2005?
