Dash lights on and key not in ignition but still dings
Old Oct 7, 2009 | 12:21 AM
michaels104's Avatar
michaels104
Default Dash lights on and key not in ignition but still dings
I have a 2004 Dodge 2500 4x4 diesel, I am having trouble with my dash lights staying on this being the odometer light and the gear selector lights as well the truck dings like the keys are in the ignition at all times even when it isn't and this is draining my batteries. The dealers say there are no codes on it, but they cant tell me what it is either. I have changed the clock spring and airbag module to no help either. Any help appreciated
Old Oct 7, 2009 | 07:51 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
If you pull the wire harness off the back of the light switch do they go out?
Old Oct 9, 2009 | 03:21 AM
michaels104
No I just tried this but that doesnt work, I found out his truck has an "autopage" systaem in it. Not sure what this is but if I unhook one of the harnessses from it the lights go out, but batteries still go low. Must ahve somehting to do with this "autopage" anyone know what this is and how to disable/remove it? Thanks
Old Oct 9, 2009 | 03:22 AM
michaels104
No I just tried this but that doesn't work, I found out his truck has an "autopage" system in it. Not sure what this is but if I unhook one of the harnesses from it the lights go out, but batteries still go low. Must have something to do with this "autopage" anyone know what this is and how to disable/remove it? Thanks
Old Oct 9, 2009 | 08:18 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Autopage as in car alarm?
Old Oct 9, 2009 | 08:27 AM
dirtydog's Avatar
dirtydog
Moderate User
sounds like you've got a bad alarm controller.
