EGR delete??
Old Oct 7, 2009 | 11:52 AM
dunerider650's Avatar
dunerider650
Default EGR delete??
Anyone figured a way to do this?? would it gain any benefit...i know it must gain some rather than having hot exhaust gasses going back into your intake system.
Old Oct 7, 2009 | 02:00 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
They make a blocking plate and there was a thread on this some time back but I dont remember what the pros and cons were.
Old Oct 7, 2009 | 03:18 PM
dunerider650
Can anyone find that post? i thought i seen something about it too but couldnt find anything under egr or egr delete...i know there was a guy doing custom tunes with the SCT and he dissabled the egr on the vehicle so we didnt throw codes...
Old Oct 7, 2009 | 04:40 PM
Ram4wd's Avatar
Ram4wd
This is a mod on the newer 6.7 Diesels as well. Might find something on the Cummins side to point you in the right direction. I was looking at a Diesel a while back and stumbled into all of this. It is apparently a part of the solution to the DPF issues they suffer. But that's all I know on the topic.
Good luck!
Old Oct 7, 2009 | 04:43 PM
dirtydog's Avatar
dirtydog
Moderate User
There is a restrictor plate that can be made to limit the maount of hot gases going into the intake which will allow you to use without setting codes.
ANything regarding turning off egr codes..etc will require a custom tune. You cannot do this with a handheld yourself. it is written inside the actual tune. My mustang had AIR injection, egr and rear 02's turned off through a custom tune. Otherwise, you will throw codes and your truck may not run right.
Old Oct 8, 2009 | 10:27 AM
ramhunter9's Avatar
ramhunter9
i dont have a EGR it is blocked with a plate no wires to be found .
Old Oct 8, 2009 | 10:32 AM
dunerider650
Anymore info on this restriction plate?? and will my motor then run to lean??
Old Oct 8, 2009 | 10:51 AM
oefootball_70's Avatar
oefootball_70
Is the EGR the tube that hooks back up to the air intake. The rubber one? I just unhooked that.
Old Oct 8, 2009 | 10:54 AM
dunerider650
Yep that would be it..it runs from the EGR to the throttle body.
Old Oct 8, 2009 | 10:58 AM
oefootball_70
SO by unhooking that, I did the cheapest version of EGR delete?
