Hey, I need some serious help
Old Oct 10, 2009 | 05:06 PM
Mr Mopar's Avatar
Mr Mopar
Default Hey, I need some serious help
Ok, So the other day I bought a K&N cold air intake for my
07' 5.7L dodge ram. *Bought it early 08'*
I just installed it, Took it for a test run, And loved it.
HOWEVER,
I floored it, And turned a corner and the engine shut off.
I turned it back on, Drove a few yards then it shut off again,
then wouldn't turn back on for 5 minutes.
I managed to get it home, But now I don't want to drive it
because it would void the warranty, And the check engine light is on.
Does anyone know what's wrong, or what I could have
done wrong?
It came with no instructions, Its an intake, you dont need it,
but there could be something I missed.
Edit: I found the problem. My Gas/Air Mixture is too lean.
What can I do to get my Intake to work without this happening?
There is some sort of program I believe but I'm not sure what.
Old Oct 10, 2009 | 05:11 PM
SilverBullet08's Avatar
SilverBullet08
well was there anything in the intake or did something fall in the tb while u were installing it?? if it did thats big problems. u need to pull the code so we can have more info
Old Oct 10, 2009 | 05:14 PM
Mr Mopar's Avatar
Mr Mopar
I don't have a scanner.
Old Oct 10, 2009 | 05:18 PM
SilverBullet08
autozone or other parts stores pulls them for free
Old Oct 10, 2009 | 05:23 PM
Mr Mopar's Avatar
Mr Mopar
Alright. I'm helping my wife install a wing on her Charger so I will get it scanned later and post on here.
Old Oct 10, 2009 | 05:39 PM
HammerZ71's Avatar
HammerZ71
did you bump the sensor inside the TB by accident? Also some of the oiled filters have been known to be a little too oiled out of the box, it's possible some oil/gunk got on the sensor...
Old Oct 10, 2009 | 05:47 PM
Mr Mopar's Avatar
Mr Mopar
Old Oct 10, 2009 | 05:49 PM
SilverBullet08
i really dont see how its too lean. i have a kn 57 series with no problems. did u reset the computer after u installed it?
Old Oct 10, 2009 | 05:51 PM
Mr Mopar's Avatar
Mr Mopar
No, How would I do that?
Old Oct 10, 2009 | 05:54 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Ive had a CAI since Ive had my truck and never an issue like this. How do you know it is too lean? Did you test with a A/F gauage and if so what were the numbers?
