A few questions about tires and wheels
Old Oct 11, 2009 | 12:55 PM
bigsam's Avatar
bigsam
Default A few questions about tires and wheels
Im looking at new tires for my truck and am thinking about moving up to 35's. I was wondering if i could fit 35's without a leveling kit. I am also looking at new wheels and was wondering what offset width and backspacing would be good for a new set of wheels to run 35x12.50 on a 2007 dodge ram 1500
Old Oct 11, 2009 | 12:59 PM
ramhunter9's Avatar
ramhunter9
good god !
again??? ok no 35's wont fit you have to keep stock till you learn the search function and FAQ section hell 4 post down this same question and 5 under that
Old Oct 11, 2009 | 01:16 PM
bigsam's Avatar
bigsam
my apologies i am awful at using the search every time i try i never find what i am looking for
Old Oct 11, 2009 | 01:18 PM
ramhunter9's Avatar
ramhunter9
check the FAQ'S on top the page tons of info in there on this subject
but in a nut shell 35's with a level you will need to trim the fender and if using stovk rims you will need spacers
Old Oct 11, 2009 | 01:27 PM
bwheelersc's Avatar
bwheelersc
ramhunter is getting pissed at us newb's
Old Oct 11, 2009 | 01:31 PM
ramhunter9's Avatar
ramhunter9
your sig is to big BW fix it before it gets deleted bro ..just a heads up
Old Oct 11, 2009 | 02:27 PM
cheapbeater's Avatar
cheapbeater
i think rh is out of beer... haha j/k
Old Oct 11, 2009 | 02:33 PM
HammerZ71's Avatar
HammerZ71
Yeah, old RH is getting tired of seeing the same tire question three or four times a day.
And he's correct about your sig, bwheelersc, 500x250 max. Resize it down to at least that size if you would. Oversize sig pics not only fill up a thread quick, but actually slow down the speed of the database.
And to the OP, 35's without a level kit is a no go... I personally don't even like 35s WITH a level kit. There is a big difference between "fitting" and being functional.
But to answer your question, with a level, you can fit 35's with a min of 4" of backspacing and any negative offset...
Old Oct 11, 2009 | 06:01 PM
Xanlamin's Avatar
Xanlamin
Even on a 2500 you need a lvl kit to run 35's, only difference is you can use your stock wheels.
