HID Help Needed
Old Oct 12, 2009 | 01:23 AM
oilslick's Avatar
oilslick
Default HID Help Needed
07 Ram 1500, installed my hids got the light flicker, did some research, but still no solid answer on what is needed, resistor? capacitor? someone who has fixed this problem must know, also, my hid kit came with its own relay harness but only 1 stock headlight plug is used, what does the other 1 headlight plug do? just chill out. and because of that my DRL turn signal shuts off both lights now? am i suposed to get rid of my DRL? someone help
Old Oct 12, 2009 | 02:36 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Resistors are the way to go. With my kits, I only have stock headlight plug used also by the ballast. The other has a short harness that plugs into it to trick the computer.
HID/Lamp Out Fix using Resistor
dodge talk.com/forums/showthread.php?t=147952
Found a Fix To My HID Problem, LAMP Out & Strobing
dodge talk.com/forums/showthread.php?t=231858
Drivers side
Passengers side
Old Oct 12, 2009 | 03:10 PM
oilslick's Avatar
oilslick
hey man, pictures are great but those 2 links you sent me wont open so im still kinda stuck at where i started, and does anyone know what todo with my DRL's? what size resistor is needed?
Old Oct 12, 2009 | 04:04 PM
bigmike005's Avatar
bigmike005
contact hidextra.com....they got what you need to make them work, dont do mickey mouse stuff on your truck.....
