Fog lights with highbeams
Old Oct 18, 2009 | 09:56 AM
nathan_m's Avatar
nathan_m
Default Fog lights with highbeams
I remember seeing a thread about how to wire the OEM fog lights different so they would stay on with the highbeams, but I cant' seem to find it in the search. Could someone send me the link? BTW I have a 2003 Ram SLT.
Old Oct 18, 2009 | 01:23 PM
irelandshemi's Avatar
irelandshemi
cant remember where the thread is at but its just a jumper wire from the foglight fuse to another one
Old Oct 18, 2009 | 03:38 PM
Lowlygovemployee's Avatar
Lowlygovemployee
Just go to the dealer and have them set it up to work. all they have to do is hook up the scanner and reset it. When I added the Mopar fog lights, I had them set mine up that way.
Old Oct 18, 2009 | 05:25 PM
RaiderJay6's Avatar
RaiderJay6
Old Oct 18, 2009 | 06:29 PM
OklaHemi's Avatar
OklaHemi
that only works on the 06+. 05 and down have relays. damn jay beat me too it
Old Nov 7, 2009 | 05:26 PM
JONKEN's Avatar
JONKEN
Default Foglight with highbeam
Can I wiring like the picture on my 06 or must I go to the workshop?
I dont have a dodge dealer near me so it should be nice if i can wire like that.
/JONNY sweden
Old Nov 7, 2009 | 05:41 PM
cheapbeater's Avatar
cheapbeater
just did mine finally! took all of 5 mins, and 3 of those were looking for wire
Old Nov 7, 2009 | 06:06 PM
dirtydog's Avatar
dirtydog
Moderate User
Problem is that the fogs are a split off the headlight wire that is only 18ga. Your maxing out that wire for power tranfser. Stuff starts to melt after long term abuse A simple bad ground could cause the issue. We all know that happens. But then again how often are you actually running your highbeams anyways? Prob not enough to worry much about it. brief intervals are nothing major. Biggest thing there is a possible popped fuse.
Old Nov 7, 2009 | 06:19 PM
toxdoc's Avatar
toxdoc
I can't remember without looking at my wiring but it is similar to the picture shown in this thread. What I "DO" remember is that there was an additional wiring change from one contact post to another. The reason for this is to not use the post that is hot with 12 volts all the time but use the post that is the low amperage ground side which is used for your switching parking lights.
I'm pretty sure the photo shown just above is the 'old configuration' which has the 12 volt hot load - look through the threads for a post by schnydz from 9/18/2006. Hope this helps!
toxdoc
Old Nov 7, 2009 | 06:45 PM
dodgenitto's Avatar
dodgenitto
I put an inline fuse just for safety sake in mine.
