Steering
Old Oct 18, 2009 | 03:14 PM
neillsdiesel's Avatar
neillsdiesel
Default Steering
Has anyone encountered stiff power steering. My steering does not "bounce back" when I let go of the wheel. Tried changing the fluid, did not work. Any suggestions?
Old Oct 18, 2009 | 03:25 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
are you sude the pump is working correctly?
Old Oct 18, 2009 | 10:31 PM
neillsdiesel
No, not sure that the pump is working correctly. Is there a simple way to check, at home or is this something the dealer has to check out?
Old Oct 29, 2009 | 12:37 AM
neillsdiesel
Does anyone else have any suggestions?
Old Oct 29, 2009 | 12:40 AM
cheapbeater's Avatar
cheapbeater
got any pinched off/ squished lines?
Old Oct 29, 2009 | 06:53 AM
dirtydog's Avatar
dirtydog
Moderate User
steering wheel doesn't go back means you need a new rack most likely, but here's a direct service statement regarding racks in general of all types.
If the steering is slow to return or "sticks" when turning to either side, it may indicate binding or corrosion in the flexible coupling in the steering input shaft, or rusted or worn upper MacPherson strut mounts.
