WOT 1st to 2nd ?
Old Dec 29, 2009 | 02:50 PM
  #21
Fav40's Avatar
Fav40
Naa I got a peg leg
It didn't sound nasty, but it was loud enough to be embarrassing. Truck is stock minus the tune. So it's not loud enough to mask a shift. It sounded like a clack. Not a clunk, thud, or bang.
It started to be noticeable shifting to reverse while the truck was fast idling (cold here now) but it was much softer. WOT 1st to 2nd was about it. Standard tune shift points
Old Dec 29, 2009 | 02:59 PM
  #22
dirtydog's Avatar
dirtydog
Moderate User
Chrysler is known to have excessive backlash in their rear differentials causing clunks when shifting into reverse or drive. i think this issue is seperate from your "clunk" that you are experiencing. Excessive backlash does produce a clunking sound but only when your not moving. Unless your shift is really delayed, there should be no clunk from the rear diff as there is pressure on the gears the entire time your moving forwards unless you were to let off the gas and the rotational speed is faster than the idle speed of the engine.
Old Dec 29, 2009 | 03:43 PM
  #23
truckin151's Avatar
truckin151
NEver noticed that with mine. Even with the converter and modified shift points there is no clunking or clanking other than putting it in gear, but it did that stock.
Old Dec 29, 2009 | 04:59 PM
  #24
Fav40's Avatar
Fav40
Invoice reads " Several updates to Engine and Transmission. Flash updates done to both. "
I like it. Truck feels better, shifts better. Seems more agressive too. It used to want to shift up to quick, with that "take forever delay".
best of all....no more noise. Predator goes on tomorrow !
Old Dec 29, 2009 | 06:51 PM
  #25
lxman1's Avatar
lxman1
Site Moderator
Let us know how it does with the Predator. I set mine to shift at 5800 and have no noise or shifting issues.
Old Dec 29, 2009 | 10:47 PM
  #26
Fav40's Avatar
Fav40
Does it have a delay from 1st to 2nd ? I thought about raising it too, but worried.
Old Jan 11, 2010 | 01:00 AM
  #27
Countryboy613's Avatar
Countryboy613
hey everyone, found out and got fix, all it was, the tires that i had put on were bigger than the factory ones, took it in to the dealer to set my speedo to match my tires. apprently the newer ram hemi's are very tempermental about that, so ive been told.
Old Jan 11, 2010 | 01:53 AM
  #28
DODGERT's Avatar
DODGERT
anyone know anything about 518 trannys??? i got a issue with shifting from first to second and second to third with my foot in it.
Old Jan 11, 2010 | 07:27 AM
  #29
Fav40's Avatar
Fav40
DODGERT, Can you describe your "issue" during shifts ?
I've got stock wheels and original tires on, re-flashed OEM computer etc. Seems to only do it when warm/hot(Tranny) otherwise it's quiet.
Old Jan 24, 2010 | 10:36 PM
  #30
Fav40's Avatar
Fav40
FYI I sold my Predator . I might try the Superchips next. More tranny adjustments.
