just out of the blue
Old Oct 18, 2009 | 07:55 PM
Ram Tuff's Avatar
Ram Tuff
Default just out of the blue
2002 ram 1500 with 5.9 ,turned a corner and started pushing on the gas and the worst backfire, misfire i've ever felt. No codes, fuel pressure good. hard to start and the exhaust stinks and it's not flooding. To me it sounds like it running out of gas. If i push slowly on the gas i can get it up to speed.
Old Oct 18, 2009 | 11:24 PM
culbee21's Avatar
culbee21
You may want to check your catalytic converter to see if it has broken apart and clogged youe exhaust pipe
Old Oct 18, 2009 | 11:42 PM
nim81's Avatar
nim81
check your plugs,wires, dist. cap and rotor. sounds like it could be your pick-up coil.
Old Oct 19, 2009 | 07:12 AM
Ram Tuff's Avatar
Ram Tuff
The exhaust isn't plugged. With the scanner hooked up , it shows while it is sitting there idling, about 6 different cylinders misfiring.
Old Oct 19, 2009 | 11:41 PM
Ram Tuff's Avatar
Ram Tuff
I found the problem, it was the coil wire burnt off in the boot.
