Oil pan replacement??
Old Oct 19, 2009 | 09:30 AM
FLASHJR's Avatar
FLASHJR
Default Oil pan replacement??
02 Ram 1500 4x4 quad cab anything special required to change the oil pan, mine is rusted and is seeping oil. how much of a hassle is it to change, any help would be great.
Old Oct 19, 2009 | 10:54 AM
Twisted Metal's Avatar
Twisted Metal
Some say you have to jack the engine or trans to get clearence. We did one on a buddy's 96 2500 4x4 and had to jack the tail shaft of the trans to get clearence for the rear of the lip of the pan.
Old Oct 19, 2009 | 02:50 PM
dhvaughan's Avatar
dhvaughan
i don't think i've ever seen an oil pan rust out. are you sure its seeping through the metal ? poke it with a small pick to be sure....
i'm not sure about your 02. for better info - you might want to repost over in the 3rd gen section.
but, on my 01, i remove the braces between engine and trans, starter, and flex plate cover. i don't have to remove exhaust pipes nor lift the engine.
as an alternative, you might clean up the exterior with brake cleaner and lay on a nice big coat of rtv.
Old Oct 19, 2009 | 04:15 PM
aim4squirrels's Avatar
aim4squirrels
Or JB Weld a metal patch on there if it ain't on a corner.
