Help on HID Uprgrade Kit Low Beam INOP
Old Oct 20, 2009 | 11:51 AM
schultzy_30's Avatar
schultzy_30
Hope this helps[/quote]
ok cool yes it helps i think im goin to give it a try and see what happends hopefully i can wire mine the same and it works plus i have to find a adapter like yours to plug in the pass side but never the less thank you for your help im goin to give it a go. thanks again
Old Oct 23, 2009 | 01:01 PM
schultzy_30
well got them to work all i had to do was wire in a resistor like you said but only on the one side driver side low beam wire and splice it into the ground everything is working. but the only thing i went driving last night for the first time and i got flashed 9 time ins the first 12 cars i passed and my highbeams were not on i think they might be to bright and now i look like a jack ***. anything i can do to tone them down or make them aim differently i certaily dont want to be flashed by every car i pass.
Old Oct 23, 2009 | 02:49 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
You just need to adjust your headlight assemblies and turn them down towards the ground a bit. Thats all. Later on you may want to invest in some good projectors that will give a cutoff line so it will not blind oncoming traffic.
Old Oct 23, 2009 | 04:41 PM
dirtydog's Avatar
dirtydog
Moderate User
Originally Posted by abarmby
weedahoe is exactly right.
You need to simulate the resistance created by the stock headlight bulbs.
HID's do not have this resistance, therefore the PCM on the truck tries to look/hunt for the head lights (the strobing effect), cant find any due to a lack/no resistance, then shuts them down as a protection.
Putting high wattage resistors of a certain value (can't remember value weedahoe might help here) causes a load for the PCM to see and the lights fire right on up.
FYI this resistor mod also cures the "lamp out" light problem
Hope this helps?
Al.
The computer monitors the current that is being drawn not the resistance. Halogen draws 55w. HID's draw 35w which is 20w less. A resistor creates resistance on the circuit which requires More current to flow through the system to obtain the desired load. So 55w is used up, 20w by the resistor and 35w by the ballasts. Resistors "eat" power. So the resistor is essentially wasting 20w here.
Hope that helps you understand it in laymans terms.
FYI...current is not voltage. it is just a result of the voltage produced.
