Problem with new HIDs
Old Oct 20, 2009 | 04:05 PM
02Regcab's Avatar
02Regcab
Default Problem with new HIDs
K so this isnt a Flicker issue this is a works sometimes doesnt work sometimes issue..
Im guessing need a relay but from what Ive read on here the HID Extra kit ( the one i ordered) is strictly plug and play guranteed no flicker and such..
Most times the passanger lamp will not ignite.. the drivers side always comes on..
Ideas ?
Old Oct 20, 2009 | 04:10 PM
OlDirtyJohn's Avatar
OlDirtyJohn
sounds like something you should call hidextra about.
Old Oct 20, 2009 | 04:33 PM
jk111's Avatar
jk111
Sounds like a bad ballast or bad bulb
Old Oct 20, 2009 | 04:48 PM
Matt99's Avatar
Matt99
switch ballasts. If the other side stops working....ballast
if the passenger side still doesn't work, check the bulb. the cheaper kits have been known to throw mismatching bulbs in their kit. make sure and check the grounds and the inline fuse also.
Old Oct 20, 2009 | 04:52 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Try reading this thread here also.
Help on HID Uprgrade Kit Low Beam INOP
