My truck is DEAD!
Old Oct 20, 2009 | 08:12 PM
ramhunter9's Avatar
ramhunter9
i think he has more since than that sils. he did what the tunner told him he is a pretty smart guy not his first rodeo
Old Oct 20, 2009 | 08:26 PM
cheapbeater's Avatar
cheapbeater
wow, thanks RH thats a big compliment coming from you... but i did try again. nothing.
it lets me read codes, and there was none, i cleared them just in case and still nothing
Old Oct 20, 2009 | 08:30 PM
Off_Road_Teacher's Avatar
Off_Road_Teacher
Originally Posted by cheapbeater
yeah... the key was turned all the way, and i didnt unplug until it told me to...
and i pulled all fuses that said ignition or pcm and turned the key... nothing
another weird thing... usually when i turn the key to the run position, the usual dash lights come on, but then turn off after a few seconds, now they just stay on...
This sounds like something that the guys at SC will have to fix for you.
Old Oct 20, 2009 | 08:35 PM
cheapbeater
i sure hope so, its looking like im gunna have to ride my motorcycle tomorrow... its supposed to be in the 30's with wind and rain, and i gotta ride 30 miles each way!
Old Oct 20, 2009 | 08:46 PM
SilsHemi's Avatar
SilsHemi
I'm not questioning his intelligence. I'm trying to help him. There is a difference.
Sil
Old Oct 20, 2009 | 08:49 PM
SilsHemi's Avatar
SilsHemi
When you plug the tuner in now, it doesn't do anything? Does it prompt you at all or it just goes to can't verify ignition?
EDIT: If you can't get it going this evening, your best option is what Jason recommended. Superchips keeps a copy of your stock file, so if there are any issues they can get you going.
Sil
Old Oct 20, 2009 | 09:17 PM
Off_Road_Teacher
Ugh, that doesn't sound like fun at all
Old Oct 20, 2009 | 09:59 PM
cheapbeater
Sil
the tuner is working fine, it goes through the setup, but when it tells me to turn the ignition on and hit next, it thinks for awile then says "cant verify ignition on"
i'm hoping superchips can just send me a fix, but im starting to think it might have toasted something in the truck...
thanks for the ideas sil, keep em coming if you got anymore, i really dont want to freeze tomorrow
Old Oct 20, 2009 | 10:08 PM
oefootball_70's Avatar
oefootball_70
you tried pulling the fuses and letting it reset that way?
Old Oct 20, 2009 | 10:14 PM
cheapbeater
yesssss.....
then again i wasnt sure what fuse to pull... i pulled every one that said "ignition" or "pcm"
