Help!!!
Old Oct 21, 2009 | 01:48 PM
korby05's Avatar
korby05
Default Help!!!
Well here is the situation. when I'm going down a hill or even sometimes on a flat my whole truck vibrates when I'm hitting the brakes it. I notice it more now since the temperature is changing. My pap said they changed the rotors and brakes a year ago but then again who knows
Another thing is when I'm driving slow like in a parking lot or something like that i hear this moaning sound when i turn and i took it to a mechanic this summer and they couldn't find the problem.
by the way it's a 2002 QC with the 5.9 in it
Old Oct 21, 2009 | 01:52 PM
Shiloh 24's Avatar
Shiloh 24
5.9 POWER WOOOO!
Ok back on subject, my guess is your front end is goin to hell. I have read numerous threads about the front ends on our trucks and how many problems they can have. I'm sure someone who knows more about the front ends will tune in. So heres a free bump for ya.
Old Oct 21, 2009 | 01:53 PM
SilverBullet08's Avatar
SilverBullet08
for the brakes check the brake fluid and the front end is prob your ball joints going out
Old Oct 21, 2009 | 01:54 PM
ramhunter9's Avatar
ramhunter9
sounds like a typical rotor or break pad to me ...But i had this last week thought the same thing rotors or pads both were fine ..it was moisture between the pad and rotor . beaings i dont drive my truck but a few times a month . it went away after a few miles
Old Oct 21, 2009 | 02:52 PM
korby05's Avatar
korby05
yeah i only drive mine couple times a month now since i'm back in school... but like i said i did notice it more this month since it has been sitting more
Old Oct 21, 2009 | 03:07 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
If it happens only when the brakes are applied then I would be chking the rotors for warpage. They are know to warp. I know you said they were replaced some time back but check them anyway. Thats what i think.
Old Oct 21, 2009 | 03:21 PM
kicker417's Avatar
kicker417
I would still check rotors and pads just weather wise can make A difference.
Old Oct 21, 2009 | 03:56 PM
korby05's Avatar
korby05
yeah thanks guys that's what i was thinking...any suggestions on what rotors to go with if they are warped..I know my pap said that you should only put "chrysler parts" on it in order for it to not do that.. but i've heard some bad things about chrysler brand rotors
Old Oct 21, 2009 | 04:50 PM
ramhunter9's Avatar
ramhunter9
oem for mine was 70 bucks a pop aftermarket was 160 the cheapest . you can also get them turned
